Results 1 to 4 of 4
Thread: Changing wooden arrow spine
  1. #1
    In the Blue
    Join Date
    Jan 2011
    Location
    Aldridge, Walsall
    Posts
    213
    I was just wondering if anyone had experience of altering wooden shaft diameter and its effect on original spine?
    I have for a while now wondered what would happen to the spine of an 11/32 heavy shaft, say Douglas Fir if I took an 80-85lb spined shaft (11/32) and then reduced the shaft to 5/16? I appreciate and understand that rear tapering will often reduce the spine by 3-5lbs but what about reducing the entire length of the shaft?
    Has anyone tried this or have any data on the same please.
  2. #2
    In the Gold
    Join Date
    Nov 2006
    Location
    Oban
    Posts
    856
    I got some new shafts a few years ago and while most were in the region of the 50-52# spine I wanted 2 were 60 & 61#. I simply kept them stock length and put them into the chuck of my electric drill and ran sandpaper up and down the shaft to reduce the diameter. I checked the spine regularly then carried on with the process, with the shaft ends swapped every time I did the check, until I got the deflection to the 50-52# spine I desired. Although the diameter was smaller it was not obvious enough to bother with. I then cut the arrows to the length I wanted and made up the arrows. As I shoot these at the field course from a horsebow they don't need to be exactly matched for my satisfaction. Hope that gives some form of answer for you to think about.
    BillM
    If you wait long enough, the inevitable will finally happen.
  3. #3
    It's an X Del the Cat's Avatar
    Join Date
    Oct 2008
    Location
    Harlow Essex
    Posts
    3,996
    Blog Entries
    2
    BillM has nailed it
    Health Warning:- These posts may contain traces of nut.
  4. #4
    In the Gold
    Join Date
    Nov 2006
    Location
    Oban
    Posts
    856
    I still bite my nails which is why I used sandpaper.
    BillM
Similar Threads
  1. Wooden Arrow Spine for AFB shot off the hand
    By Microphonic in forum Arrows & Components
    Last Post: 11-06-14, 02:57 PM
  2. Changing 100% Carbon Arrow Spine
    By albatross in forum Methodology, Tuning, Coaching etc.
    Last Post: 03-09-13, 08:36 PM
  3. 23/64 100 spine wooden arrow shafts.
    By tinturkey in forum Traditional Bows (Archive)
    Last Post: 13-03-12, 06:47 PM
  4. Replies: 12
    Last Post: 06-03-12, 11:14 AM
  5. Replies: 5
    Last Post: 18-01-11, 10:16 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
