misstheboss1973
Hi all. New to the forum so thanks in advance...its a great site!
im relatively new to archery but recently bought a bear anarchy compound 60-70lb for informal target & 3D/field shooting. After lots of research on arrows I decided to try the Easton axis FMJs in 300 spine based on strength, durability, small diameter & gpi. I bought just a couple of shafts to fletch and add inserts & points to until the new bow was set up properly. I then ran into a 'problem'...
The shafts came with the deep 6 rps inserts (my choice as have read bad things about the HIT inserts. I also bought the Easton deep 6 field points to go with them (the ones with the bulge). After screwing in I noticed that the diameter of the rear of the point (the rear of the bulge) is smaller than the arrow diameter. Is this ok? It looks a bit weird...
So I seem to have a few options...
a) Ignore it. It's not s problem and won't affect arrow or target wear (or accuracy).
b) Buy a set with the HIT inserts and fit standard 9/32 rps points (good as will have choice of point weights. But heard lots about split shafts/mushrooming with the HIT)
c) look for a different low diameter shaft. Like the look of the injexions but no one seems to sell them in the UK.
d) Try ordering the Easton points (from abroad) in a different size. I notice the points are available as DP6-5 and DP6-4. And in a 125g option. Anyone have any experience of these and know which matches the 300 axis shaft?
Your thoughts would be very welcome. Many thanks
