chrisnoble
This is the SF Elite Wheeled Case 116cm model. Made from heavy duty nylon with padding and internal frame it can take some stick (but it hasn't yet) It's large. It can store 2 recurve set ups and spotting scope, outdoor wear etc. It is also suitable for compound bows but I have never shot compound and so cannot comment if it can store more than one bow. It has wheels or side handle and even back pack straps.
Remember the bag opens like a clamshell so the bow compartment is as follows:
113cm long, 40cm wide and 10cm deep. The internal straps attach by velcro and so can be fitted anywhere to suit. And the corner cases stick anywhere too. The compartment is separated with a padded cover going the entire length and width.
On the opposite side measures as follows:
113cm long, 40cm wide (divided into a 14cm and 26cm section) and 8cm deep
As in picture it comes with an arrow case and accessory case which hold on position with velcro. The remaining section can be used for arrow tubes, clothing, scope. Just about anything you are likely to want to take to a tournament in U.K. or abroad.
External dimensions are:
116cm long
43cm wide
26cm deep
116cm long
43cm wide
26cm deep
