Arch Stanton
Having finally got a chance to follow up all of your good advice regarding my arrows going to the right at distance, I've managed to get hold of a couple of line levels today and have discovered that my sight track is indeed not parallel with the string.
To correct the discrepancy it looks like the sight clamp needs packing out at the lower side which would be entirely consistent with the arrows going to the right at distance.
Any suggestions what to pack it out with ?
I'm a bit concerned that the if I just pack it out at the lower edge, then the flat base of the clamp will hardly be in contact with the riser at all. I imagine something wedge-shaped would be the perfect solution ?!
