Yes, I trawled the first 3 pages on this board and saw no mention of what I'm about to ask.
I'm hoping to score some 2nd hand A/C/E's by the weekend. They are 28 3/4" 470 spine with 100 gr points. I'm going to re-sock/re-fletch them to my usual colour scheme with 1.5" Bohning Shield X-Vanes & replace the G-nocks with pins....
1) How do you decide what distance to use between the nock-end & the start of the vane?
- is it purely down to personal preference or is there a 'magic formula'? Or at least a recommended min/max?
A 470 spine is perhaps just a wee bit stiff for right now, but it's indoor season (X-Busters & 36# limbs) so by the spring I'll have my 44# limbs screwed up to (close to) max if not actually using 46# or 48# so I'm guessing I'll be roughly a hair under 50# OTF by then which should be close to OK. But in case I do some 'iceman' outdoor shoots over the winter....
2) What point-weight would 'soften' the spine closer to 520? Is 120 gr enough? That seems to be the max in Easton points but I have seen 150 (& heavier!) on the 'bay, they're 4.2 mm is that compatible? (Even the Easton website doesn't give the diameter)
Well what did you expect from me, easy questions?
