Here's another interpretation in red where I've tried to make the curve enter the lever at the correct angle. It again shows too much bend near the grip, but the rest looks better.
A higher resolution picture would allow better fit of curves and better analysis.
Hopefully this gives some ideas.
You can also ask yourself... If pulled to destruction where do you think it would fail... my bet is on the fade.
It's sort of self regulating, a little off the mid to outer, will make that bend more and make the fade area slightly stiffer in comparison, taking some load of it... so small changes can make big improvements.
Slow and steady wins the day...
A little and often...
(Other platitudes are also available
Join the Primitive Archer forum and post a better resolution pic asking for a tiller check.
You'll get good honest advice from people who have made Mollegabet bows.
I reckon you are 99% there, it's just subtlety and getting your eye in now. It's easy to become "tiller blind", which is why the tiller check posts are V common.
