Two Colour/Candy Stripe Strings
MikeD
Are they legal, or are they considered to offer a marked string?
I like my black and yellow string, but if there is any doubt I'd rather make up some single colour strings now...
Kae
The American
I've never heard of anyone having any problems, and although I don't have the rule book to hand, I'm sure there is nothing in the rules against multicoloured strings.
I've shot at record status events with 4 tone strings before and never had a problem.
Kae.
TJ Mason
Soaring
Certainly legal for GNAS shoots.
GNAS Rules of Shooting 202.b.i, defining the bowstring for recurves, allows "any number of strands that may be of different colours".
Schme1440
Target shoots dont matter. They dont have a rule. however field shoots I dont know. I know they use to have a rule but I think they may have relaxed on it a bit. I know they banned a particular serving colour years ago. It was a rainbow design. If you dont shoot field rounds then dont worry.
MikeD
Cool thanks. Only trouble is I now have to buy reels of black and yellow so I can make my own strings... Ah well it's only money :)
MINIMike
My Matrix looks lovely with it's new blue and silver strings. Worth an extra 10 points - even if only in my mind! :mind-blow
It's not against the rules, looks good and will give you something to do on those cold and wet winter nights. Go for it!!!!!
jerryRTD
I like two for keeping the placement of fingers/tab on the string the same each time.
So do I but if you use a finger separater you can slide the top of the tab gap down the string until it butts against the top brass nock and get a good location.
Tropicalshot
Recurve fita rules state
7.3.1.2 A bowstring of any number of strands,
7.3.1.2.1 which may be of different colours and of the material chosen for
the purpose. It may have a center serving to accommodate the
drawing fingers, a nocking point to which may be added serving(
s) to fit the arrow nock as necessary, and, to locate this
point, one or two nock locators may be positioned. At each end
of the bowstring there is a loop which is placed in the string
nocks of the bow when braced. In addition one attachment is
permitted on the string to serve as a lip or nose mark. The serving
on the string must not end within the athlete?s vision at full
draw. The bowstring must not in any way assist aiming through
the use of a peephole, marking, or any other means.
compound fita rules state
7.3.3.2 A bowstring of any number of strands,
7.3.3.2.1 which may be of different colours and of the material chosen for
drawing fingers or release aid. Nocking points may be fitted to
which may be added serving(s) to fit the arrow nock as necessary.
To locate these points one or two nock locators may be fitted.
In addition attachments are permitted on the string such as a
lip or nose mark, a peep-hole, a peep-hole ?hold-in-line? device,
loop bowstring, etc.
fita std bow states
7.3.2.1.1 The bowstring material may not be of a higher specification than
Dacron.
so as you can see they both allow different colours
FlourPower
NFAS Barebow: The bowstring may be of different colours as long as they run continuously and evenly throughout the string's length, but the serving shall be of one colour. One nocking point is permitted.
