P
pyroarch57
Guest
Nice eh:cheerful:
Yes Geoff coming shortly.Pyroarch 57, A dream to use;Yes. Screws coming out=no problem. First thing I did with mine after shooting it was to take them all out and find out what makes it tick. It is so simple in the Loesch that it makes me wonder why there aren't others like it. Two moving parts(both can be seen from outside) and a tension spring to adjust the release tension.And nothing jumps out when it is taken apart.:cheerful:
Your photo shows the evo cocked and ready to draw, I think. What does it look like when it has released? You couldn't post a pic showing that could you please? I'm just curious to see if it is similar to the loesch.
You`re very welcome Sir. If you need any more info feel free:cheerful:Hey that is great. I was curious about the released picture as I thought I might be able to get some insight into its insides. And hey presto you came up with a see through version ???:cheerful: Excellent. Thank you very much pyroarch 57. It still has the two main parts like the Loesch but the adjustment is more subtle and the safety is inside. Very neat. I am going to be very tempted to make one of those.
There`s 2 other springs, but they don`t come with the release.I liked the idea so I tried Lez Newsome's evolution at Shotton ...
Let's just say for me it was an unusual type of trigger release. Aim, depress the safe.. gone.
Do they come with different spare springs?
Is one of them stiffer than standard, I believe the standard spring is for upto aprox 20lbs holding weight, is there one for 20 - 25lb ish (going on 7.5 ton )There`s 2 other springs, but they don`t come with the release.
There`s an 8-17 12-20 20-38 and 16-36Is one of them stiffer than standard, I believe the standard spring is for upto aprox 20lbs holding weight, is there one for 20 - 25lb ish (going on 7.5 ton )
