There are no standards, the fitting is a copy of Hoyts bow fitting with each manufactor making their own version and I guess allowing a little extra clearance so their bows/limbs fit every one elses :vomit:Yet another story of bad fitting limbs;
I have a sf pro carbon riser (buy the best you can afford) and winstorm limbs.
The bottom limb when strung rocks from left to right.
So took the bow apart.
D slots in limbs top 9.5mm, bottom 9.75mm.
Location pins in the riser 9.4mm top & bottom.
When I phoned the supplier they told me this was acceptable!!!!!!!!!!!!!!!
So how do you adjust the string centre?
Everything you build the bow it sounds like!
What are the standards if any?:rottentom
Lets be realistic here...you have bought a riser from the higher end of the scale, and limbs from the bottom end.Yet another story of bad fitting limbs;
The answer might start with a H or a B......:yummy:I am getting very frustrated with moving groups. I don't know WHEN they're going to move, but I know they will.
I've not excluded the fact that it may be me, but when you're hapilly filling an 8cm gold at 18m then suddenly you're in the 7/8 ring (sometimes it moves slightly over 2 or 3 ends, other times it's just there), it's very frustrating.
This problem saw me shooting well at the European invitational at stoke last year then get soundly thrashed in the H2Hs by a guy I should have easily taken out - of course, in a H2H there is little or no recovery time. I've learned to move my sight more quickly, but it's still throwing away points.
It doesn't seem to matter which of my two risers or sets of limbs I use (I chose my backup bow for H2Hs in Stoke...)
As I said, could be me, but I'm now seriously looking for ways to remove the limb/riser variable!
Err....Sid, how to you tune arrows?:worried:We working my behind off on this exact problem...
We are working on an Non ILF riser which Has ILF compatable with a shoe.
Our 17" design has been posted, but taking on a project this size doesnt come without delays. we are going to work on the 17" and 25" to start with. then fill in the riser sizes. Someone coined the term BGB (bloody Great Bolt) is bulletproof!
The other one is, if you can hold 40lbs on your fingers for a whole day, why would you want to detune your bow to 38lbs so your arrows tune... why not tune arrows to 40lbs and have the extra 4fps on your side (assuming 1lbs is 2fps)
Thats my wee rant on adjustable lbs risers....
