EvadingGrid
Yes its a bad idea to assume that just because the ILF fittings are the right dimensions that the bow will end up right - it could go either way. I've seen hybrid bows that worked and scored top points at county matches, and I've also known bows best described as "horror stories".You just have to remember that ILF is a myth. People copied the Hoyt fitting on the GM, more or less. But there has never been an ILF - no standard, no agreed set of measurements. So of course you can't guarantee that one manufacturer's limbs will fit another's handle. That so many are more or less interchangeable, is frankly, a miracle
