I can only comment on the FiberBow S3, try one, it's the only way to understand the feel, feed back and dampening qualities and if your kit is poorly set up and everything is hidden by rubber you will soon find out. Good shots are rewarded with a crisp fresh positve feel to the shot on a FB almost stealth like, on an aluminium handle not as quiet but still better than the rest. The feedback on a poor shot leaves you in no doubt. For me the best bit is the stability at full draw and the reduction in those all-beit small small wibbly wobbly movement during and immediately after the shot . For some though a stiff set up may not be the best option it might be less forgiving of poor form (not that mine is anywhere close to good it has to work hard ) the Easton X10 might be a better bet. IMO for compound, based on feed back from good archers that have shot using one rather than my limited experience there is no equal even on a Bowtech that doesn't need much help.
