bearded bowyer
Hi all
Whilst Del is busy exploding warbows, I finally thought the time had come for me to have a go. I normally shoot 50lbs, but dream of the days of old. (oh, and a crazy Welshman has asked if I can make him one, and he has offered me money!!!) but the first one is for me.
I have very quickly discovered that this is WAY different from any other bow I have made.
I glued up a basic hickory and lemonwood stave, hoping this is most likely to survive my amateur approach, and set to work.
for those of you who havn't had a chance to play with lemonwood, it is looovely. It planes, spokeshaves and scrapes like butter.
I got the stave roughly how I wanted it over the weekend and put a long string on it. ( pictures to follow)
good sweeping curve evenly through both limbs.
Got it bending nicely to a fistmele, and tried to string it like I would normally string a 50lb bow, using the push pull method. I tried and tried to string it untill my back went ping! then cut a couple of extra nocks and made a stringer. ouch!
BUT I dont have a winch system so, hanging off the bottom of my tillering string (good traction for my back) I managed to weigh it at 76lbs at 24 inches, with a really even sweep in both limbs. I just couldn't get it any further!
I thought I would take it off and have a test shoot with it and ran into 2 problems:
1/ I could only draw it about 22 inches. ( I normally 30 inches to my drawing point at the corner of my mouth.)
2/ The string is no where near center handle. I could use it as a 'modified cut through' but really want the string center.
Sooooo......to address point 1/ I assume I just need to keep using it, trying to pull it further back, untill eventually I can achieve full draw.
And for 2/ I need to remove wood from the side I want the string to go towards.
BUT, how in the heck do I make a pulley to check it beyond 24 inches.
Over to all of you!
Bent double with sciatica.
Matt
Over to all of you!
Matt
