Just in case you have to stiffen or weaken a set of (expensive) A/C/Es and do not want or cannot cut them or lenghten them (more difficult).
If you are using 100-grain piles wou might have two choices. Using the 120-110-100 cut down to 100 or the full-length 100-90-80.
If you install the full-length 100-90-80 pile you will have a much stiffer arrow than with the cut down 120-110-100 pile and your total arrow length shall be reduced by 1/4" but will still have the same tube length.
The reason is the internal tail length of the insert making the tube stiffer.
