Could you elucidate, please?joetapley said:tel
.... Length of stabiliser might be the limiting factor.
But that gets into a "how good is 'good enough'?", type of question - opinion, rather than fact. At least with the "what setup will reach 100 yards?" question, you can give definitive answers. The "least" setup for that I've heard of so far, was Murray's 34lb/ACEs...Max said:Surely though, accuracy and grouping are an issue here? I accept that just to get the distance, a fairly light bow will lob an arrow 100 yards at high trajectory, but then we begin to suffer from the same problem that longbows do and get killed by cross wind. Maybe the question should be how light can you go and still retain the advantage of relatively flat trajectory and short time of flight?
But surely Rik that is the whole point? The "how good is good enough" question is important, because it has to be subjective. You have to ask "can I live with the additional variability that a lower draw weight will imply". Opinion and perception are important. You want to hear that someone else in a similar position to yourself can shoot good groups with this or that set up, without using unusual aiming techniques.Rik said:But that gets into a "how good is 'good enough'?", type of question - opinion, rather than fact. At least with the "what setup will reach 100 yards?" question, you can give definitive answers. The "least" setup for that I've heard of so far, was Murray's 34lb/ACEs...
When you point your bow upwards, the stabiliser points up too... If it's long enough and the angle is extreme enough, the target is hidden behind the stabiliser!Max said:JohnK's post is the second time stabiliser length has been mentioned as a factor in limb weight choice versus distance - how does this work?
jadlem said:shorter arrows mean less weight held at the fingers for a given set of limbs too.
Bow tune, efficiency of the archer/bow/arrow system and physical dimensions of the archer are all factors in this.
Another illustration of how variable the factors are, my recurve setup:
30" acc 500 spine, light points, 70" bow winact with long limbs 39lbs at my draw length, could barely get 80 yds sensibly on the sight.
My wife: 28" 810 navigators, 68" aerotec and everest carbon limbs with a very thin string using beiter nocking points could get the distance. The same arrows out of her 30lbs compound make for an almost flat trajectory out to 100yds too.
