What difference in performance would you expect to see between the different cores on offer???
Hex 6-w
Hex 6-S
Hex 6-h
What sort of performance increase would you expect to get over a set of Hex 5-h's???
Also, does the BB modifications effect speed, or is it more to do with stability???
Cheers
Wood core. Bread and butter... Staple of most bows.
H core. 20% lighter in density. this equates to abotu 2-3fps increase in speed. For those that have questions about wood cores changing with temperatre. (i think there are bigger variables out there than that) the core is dimensionally stable between -20+50deg C. that is the materials remit in life.
the S core is a similar desnity to the wood core. yet still has a temperature stability question removed about it. since it shares its stability with the H core.
Both of these cores are NOT foams.
the BB1 is a torsional stability increase.
The BB2 is about 3-5 fps speed gain. but it includes the BB1 upgrade.
Ive said this before. i think if your confident in the wood core. and want the faster limb. id opt for the wood core BB2.
but i'll let others fill in other blanks.
the BB2 is smoother than the standard limb too.
